Xerox wc 416s
30/1/2008 07:59PM
SALUDOS A TODOS LOS TECNICOS DEL FORO, EL EQUIPO ME MUESTRA , EL CODE C44 , Y ALO RESETEE Y AUN ASI ME SIGUE MOSTRANDO EL CODIGO , ME PODRIAN DECIR COMO SOLUCIONAR EL TEMA , SE LOS AGRADESCO DE ANTEMANO
31/1/2008 02:16PM
es un fallo del termistor,desmonta el fusor limpialo y en el peor de los casos termistor o fusor nuevo. Te dejo manual que explica la falla. suerte
31/1/2008 02:25PM
C41 Indicates a failure of the thermistor or the heater when the machine is switched on.
C43 and C44 indicate a failure of the thermistor or the heater after the machine is switched on.
C46 Indicates a failure of the thermistor or the heater after Start Print.
Procedure
WARNING
Fuser surface can be hot. Allow the fuser to cool if necessary
Perform the following:
Check the thermistor:
Check that the thermistor connectors are pushed fully home.
The main / sub thermistor (front side) are in contact with the heat roll.
Check the main / sub thermistor harness for damage, Wiring Diagram 6.
Install a new fuser, PL 4.25 Item 1.
Check fuser heater:
Fuser heater and connections. Refer to Wiring Diagram 1 and LVPS.
Check thermostat.
Install a new LVPS, PL 9.10 Item 11.
Check Interface PWB:
Check the connector CN44 on Interface PWB. Refer to Wiring Diagram 6.
Install a new interface PWB, PL 9.30 Item 5.
Reset the status counter:
Press the 0 and 8 keys simultaneously and switch on.
Input 400 using the numeric keys, and press the enter key.
Change displayed status counter to 0, and press the enter key.
Switch the machine off then on. Check that the machine returns to the normal standby mode.
NOTE:
When a C41, C43, C44 or C46 error status code is initiated and a value other than 0 is recorded, the status counter must be reset to 0 (0 = no error) before the error condition can be cleared, refer to GP 9.
