Ricoh 6645 codigos de error
08/5/2005 02:32AM
Hola:
Necesito saber los códigos de error de la Ricoh 6665 y 6665.
Gracias
10/5/2005 02:23AM
Decime que codigo te hace falta Marcos
11/5/2005 04:58AM
Todos los que puedas. Acabo de adquirir dichas máquinas y necesito estar preparado para cuando aparezcan.Gracias
02/7/2007 01:24PM
bueno, yo tambien deceo saber a que se refiere el c de error 600
02/7/2007 01:40PM
hola ,aca te dejo los codes de error ..
Code Description
101 Exposure lamp
103 Power frequency problem
104 Exposure lamp
120 Scanner home problem
121 Scan home problem
125 Scanning too slow
126 Scanning too fast
127 Scan drive problem or encoder
140 Lens home problem (vertical)
141 Lens home problem (vertical)
142 Lens home problem (horizontal)
143 Lens home problem (horizontal)
144 3rd scan sensor problem
145 3rd scan sensor problem
146 Magnification problem
190 Optics thermistor open circuit
191 Scan motor thermistor
302 Charge corona short
303 Charge corona cleaner problem
341 Developer motor drive problem
342 Toner disposal motor drive problem
343 Vsp. Problem. Image density sensor problem
351 Vsg. Problem. Higher than 4.3 volts. Image density sensor problem
352 Toner sensor problem during developer calibration
353 Vsp Problem. Image density sensor, drum bias or HVT
354 Vsg Problem. Image density sensor, drum bias or HVT
355 Toner density sensor problem. Vtd problem. Undertoned
356 Toner density sensor problem. Vtd problem. Overtoned
357 Vsp problem. Image density sensor, drum
358 Vsp problem. Image density sensor, drum, toner dust
361 Drum potential sensor calibration during process control setup
364 Vd problem. Drum potential sensor, drum or charge corona
365 V1 problem. Drum potential sensor, drum, charge corona, dirty optics
402 Transfer, transfer belt, HVT
440 Main motor speed problem
442 Drum thermistor
500 Bypass feed
501 Paper feed motor
502 1st lift motor
503 2nd lift motor
504 3rd lift motor
506 LCT motor
507 LCT feed motor
508 Tandem fence motor
510 Tandem side home sensor
511 Tandem side home sensor
520 Duplex/fuser drive motor problem
522 Jogger home sensor
523 Jogger home sensor
541 Fuser thermistor
542 Fuser does not warm-up
543 Fuser temperature too high. Monitored by main board
544 Fuser temperature too high. Monitored by optics board
545 Low fuser temperature. Monitored by main board
546 Low fuser temperature. Monitored by optics board
547 Fuser lamp won't shut off
548 Erratic fuser temperature
600 Communication problem between main board and operation board
601 Communication problem between main board and optics board
602 Communication problem between main board and high voltage unit
603 Main board problem
620 Communication problem between main board and document feeder boards
621 Communication problem between main board and sorter staplers or finisher
700 DJF/RDH feed motor
701 DJF/RDH transport belt problem
702 DJF exit or RDH inverter motor
703 RDH exit motor problem
730 Sorter/stapler or finisher transport motor
731 Bin lift motor
732 Tray shift motor
733 Tray shift lift motor
735 Duplex jogger motor
737 Gripper motor
738 Staple motor
740 Staple drive motor
741 Bin rear plate motor (stapler)
742 Finisher stack feed motor
900 Total counter
901 Total counter
SC Full waste toner bottle. Technician must empty this. Emptying the waste toner and reinstalling the bottle will clear this code
saludos y suerte
07/1/2010 08:53PM
hola que tal tengo un problema, con una ricoh 6645 mira saco la copia pero sale negra es decir no imprime nada que puedo hacer en este caso, porque la verdad esque tengo que entregar la maquina sacando una buena copia ayudenme porfavor.
07/1/2010 08:54PM
