[Solucionado] Necesito Manual de mantenimiento de Sharp AL 1530
03/11/2005 09:05PM
Por fabor quien me puede ayudar con los codigos de mantenimiento de la copiadora sharp AL 1530 Muchas Gracias...
03/11/2005 10:24PM
Hola:
Para entrar a modo ajuste/simulacion
Clear/exposicion/clear/exposicion y para ingresar los codigos y subcodigos con tecla Print:
01 Optical system:
subcodigo:
01 Mirror scan operation
06 Aging of mirror scanning
02 SPF Individual load operation:
subcodigo:
02 SPF sensor status display
03 Motor ON
04 Paper feed solenoid ON
05 Pressure release solenoid ON(RSPF)
06 Resist clutch ON (RSPF)
07 Gate solenoid ON (RSPF)
05 Lamp ON check:
subcodigo:
01 Operation panel display check
02 Fusing lamp, cooling fan operation check
03 Copy lamp ON
06 Machine individual load operation:
subcodigo:
01 Paper feed solenoid ON
02 Resist solenoid ON
07 Aging:
subcodigo:
01 Warm-up display and aging with jam
06 Intermittent aging
08 High voltage output check
subcodigo:
01 Developing bias
02 Main charger (Grid high)
03 Grid voltage (Low)
06 Transfer charger
10 Other None Toner motor aging
14 Trouble reset None Cancel of troubles other than U2
16 U2 trouble reset None Cancel of U2 trouble
22 Counter display
subcodigo:
04 JAM total counter display
05 Total counter display
08 SPF counter display
12 Drum counter display
14 P-ROM version display
17 Copy counter display
18 Printer counter display
19 Scanner mode counter display
21 Scanner counter display
22 SPF JAM counter display
24 Special counter clear
subcodigo:
01 JAM total counter clear
04 SPF counter clear
07 Drum counter clear
08 Copy counter clear
09 Printer counter clear
13 Scanner counter clear
14 SPF JAM total counter clear
15 Scanner mode counter clear
25 Main motor On:
subcodigo:
01 Main motor operation check (Cooling fan motor rotation check)
10 Polygon motor ON
26 Various setup 01 Manual feed setup
subcodigo:
02 (R) SPF setup
03 Second cassette setup
04 Machine duplex setup
06 Destination setup
07 Machine conditions check
20 Rear edge void setup
30 CE mark support control ON/OFF
38 Cancel of stop at drum life over
39 Memory capacity check
40 Polygon motor OFF time setup
(Time required for turning OFF after
completion of printing)
42 Transfer ON timing control setup
43 Side void setup
44 SPF document rear edge read setup
62 Energy-save mode copy lamp setup
63 Fan control select setup
30 Sensor operation check (Standard provision)
subcodigo:
01 Paper sensor status display
43 Fusing temperature setup
subcodigo:
01 Fusing temperature setup (Normal copy)
04 Fusing temperature setup 2
05 Fusing temperature setup in duplex copy
09 Setup of fusing control of postcard size paper
46 Exposure adjustment
subcodigo:
01 Copy density adjustment (300dpi)
02 Copy density adjustment (600dpi)
18 Image contrast adjustment (300dpi)
19 γ table setup or AE operation mode setup
20 SPF exposure correction
29 Image contrast adjustment (600dpi)
31 Image sharpness adjustment
32 Copier color reproduction setup
48 Magnification ratio correction
subcodigo:
01 Front/rear (main scanning) direction and scan (sub scanning) direction
magnification ratio adjustment
49
subcodigo:
01 Flash ROM program writing mode
50 Lead edge adjustment
subcodigo:
01 Lead edge image position
10 Center offset adjustment
18 Memory reverse position adjustment in duplex copy
19 Duplex copy rear edge void adjustment
51 Timing adjustment
subcodigo:
02 Resist quantity adjustment
53
subcodigo:
08 SPF scan position automatic adjustment
61 Laser system operation
subcodigo:
03 Polygon motor check
(HSYNC output check)
63 Shading
subcodigo:
01 Shading check
64 Self print
subcodigo:
01 Self print
Espero que te sirvan
Wink
