hola tengo un error en mi ploter pro 7800 el error es 000100
04/4/2013 07:45PM
hola tengo un error en mi ploter pro 7800 el error es 0001002d porfavor si me pueden ayudar es urgente
05/4/2013 03:42AM
A ver si esto te ayuda en algo.
one answer posted is this
Please follow the following instructions precisely?.
2) Hold down the ?Paper Source? button + ?Cut Eject? button + 1 paper feed button (Down arrow)
3) POWER ON, whilst holding the buttons.
4) ?View Counters? should appear on the display, so press ?Paper feed? button down until ?Clear Counters? is displayed.
5) Press ?Select type? button + Paper Feed button + wait until ?Cleaner? is displayed.
6) Press ?ENTER? button TWICE
7) Switch machine OFF
Cool Switch machine ON
The error display should then have disappeared, and should read READY
This process can ONLY be followed ONCE before an engineer is required.
Hope this is of help
05/4/2013 11:21AM
si es una opcion el problema es que me pones signos de interrogacion gracias me odes espesificar que se ignifican los signos de interrogacion. gracias hermano
