error c6400 kyocera 1820
23/2/2007 06:15AM
amigos se alguem puder me ajudar,gostaria de saber como ento em serviço na km 1820
23/2/2007 11:51AM
O ARQUIVO QUE EU TENHO E MUITO GRANDE PARA INVIAR E DA KM2030
O CODIGO E IGUAL PRATICAMENTE EM TODAS.NO ENTANTO
No todo en mayusculas por favor ( No all in capital letters please)
http://www.yoreparo.com/foros/reglamento.php
23/2/2007 12:30PM
Hola :
C6400 =
Zero-crossing signal problem
• The engine PWB does not detect the
zero-crossing signal for the time
specified below.
At power-on: 3 s
Others: 5 s
Posibles causas
Poor contact in
the connector terminals.
Check the connection of connectors YC7
on the engine PWB and YC2 on the power
supply PWB, and the continuity across the
connector terminals. Repair or replace if
necessary.
Defective power
supply PWB.
Check if the zero-crossing signal is output
from YC2-11 on the power supply PWB. If
not, replace the power supply PWB.
Defective engine
PWB.
Replace the engine PWB if C6400 is detected
while YC2-11 on the power supply
PWB outputs the zero-crossing signal.
Reseteable con :
U163 Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Entras asimulación así:
Start,System menú,service setting select, enter,163,enter,ejecute,exit
Exito.
Luis
P.R. Very Happy
LACTECH Moderador 3420
24/2/2007 03:41AM
te dejo el manual espero te sirva
24/2/2007 04:39AM
primero intenta la simulación U163
abres la tapa superior
te ubicas en configuración de servicio
luego pulsas la tecla #, start y luego enter
al realizar esto en el item configuracion de servicio te aparece un nuevo submenu llamado modo de mantenimiento
le das enter
luego pulsas back
con el navegador ubicas el codigo U163
lo ejecutas
Al hacer esto el equipo debe empezar de nuevo
si te vuelve a mostrar baja la unidad fusora y revisa todos sus componentes
te recomiendo el uso de un acondicionador de voltaje de 1000 watts
24/2/2007 04:40AM
se me olvido que para poder entrar en configuracion de servicio primero pulsas la tecla system menu
28/3/2007 03:00PM
suerte
KM-1820ENSM.pdf  (3.74 kb) -
