Codigos de error canon
12/12/2006 11:44PM
Hola a todos:
No se si alguien del foro tenga los codigos de error de las IR 400 de las copiadoras canon ... gracias
12/12/2006 11:49PM
marcillo escribió:Hola a todos:
hola que codigo buscas?
aca te dejo unos cuantos,si nesecitas alguno avisa que te ayudamos..
E000 - Fixing temperature fails to rise
E001 - Fixing temperature rises abnormally
E002 - Fixing temperature fails to reach a specific value
E003 - Fixing temperature drops abnormally
E007 - Fixing film has become displaced
E010 - The main motor fails to lock
E030 - Total counter failure
E031 - Option counter failure
E032 - The copy data controller counter is faulty
E051 - The horizontal registration home position detection mechanism fails
E064 - The high voltage (primary charging, transfer charging, developing) output is faulty
E100 - BD Error
E110 - The laser scanner motor fails to lock
E190 - RAM error
E191 - Communication error between the DC controller & composite power supply
E202 - Scanner home position cannot be detected
E220 - Scanning lamp fault
E240 - Communication error in the DC controller
E243 - Communication error between control panel & image processor PCB
E261 - Error in the zero cross signal
E301 - Intensity of scanning lamp is not correctly adjusted
E400 - Communication error between copier and RDF-G1
E401 - Pick up error in RDF-G1
E402 - Belt drive fault in RDF-G1
E403 - Feeder fault in RDF-G1
E411 - Original tray paper sensor/ registration sensor in RDF-G1
E422 - Communication error between copier and ADF-F1
E710 - Error in IPC communication
E711 - Error in IPC communication
E712 - Error in communication with the feeder
E713 - An IC error has occured (sorter)
E716 - Communication error with the pedestal
E717 - Communication error with the copy data controller
E803 - Error in the output voltage of the composite power supply PCB
E901 - Pedestal motor or controller PCB
saludos y suerte
