Codigo de partes de aficio mp4500
11/2/2011 01:52PM
Buen dia por favor amigos me urge saber el codigo de partes de la banda de transferencia de una aficio mp4500 (maquina de color) y si tienen todos los codigos de partes de ese modelo mejor y de la 2232c y 3245c todas copiadoras a color por favorrrrrrr
11/2/2011 04:01PM
Saludos KAMARADA, le proporciono la sig. informacion:
Ricoh AFICIO MP4500 - Transfer Belt Genuine (Banda de Transferencia)
No. de Parte RICOH: A232-3880, C2085-5474
No. de Parte GESTETNER: A232-3880, C2085-5474
No. de Parte LANIER: A232-3880, C2085-5474
No. de Parte SAVIN: A232-3880, C2085-5474
MOdelos Compatibles: Ricoh AFICIO MP4500, Gestetner 2135DPE, Gestetner 2145DPE, Gestetner 3235, Gestetner 3235E, Gestetner 3235S, Gestetner 3245, Gestetner 3245E, Gestetner 3502, Gestetner 3502P, Gestetner 3532, Gestetner 3532S/P, Gestetner 4235G, Gestetner 4245G, Gestetner 4502, Gestetner 4502P, Gestetner 4532, Gestetner 4532S/P, Gestetner DocuStation 350Z, Gestetner DocuStation 450Z, Gestetner DSM635G, Gestetner DSM645, Gestetner DSM645G, Gestetner DSM735, Gestetner DSM735E, Gestetner DSM745, Gestetner DSM745E, Gestetner DSM745EP, Gestetner DSM745ESP, Gestetner DSM745ESPF, Gestetner DSM745ESPI, Gestetner P7045, Gestetner P7145, Gestetner P7245, Gestetner SP8100DN, Lanier 2045, Lanier 2145, Lanier 5235, Lanier 5235MFD, Lanier 5245, Lanier 5245MFD, Lanier 5435, Lanier 5435MFD, Lanier 5445, Lanier 5445MFD, Lanier 5635, Lanier 5635P, Lanier 5645, Lanier 5645P, Lanier LD035, Lanier LD040B, Lanier LD040SP, Lanier LD040SPF, Lanier LD045, Lanier LD050B, Lanier LD050SP, Lanier LD050SPF, Lanier LD135, Lanier LD140G, Lanier LD140SP, Lanier LD145, Lanier LD150G, Lanier LD150SP, Lanier LD235, Lanier LD245, Lanier LD335, Lanier LD345, Lanier LD345SP, Lanier LP145N, Nashuatec 3525, Nashuatec 4525, Nashuatec D3525, Nashuatec D435, Nashuatec D435S, Nashuatec D445, Nashuatec MP4000B, Nashuatec MP5000B, Nashuatec SP8100DN, Ricoh AFICIO 1035, Ricoh AFICIO 1035P, Ricoh AFICIO 1045, Ricoh AFICIO 1045P, Ricoh AFICIO 2035, Ricoh AFICIO 2035E, Ricoh AFICIO 2035EG, Ricoh AFICIO 2035G, Ricoh AFICIO 2035P, Ricoh AFICIO 2035S, Ricoh AFICIO 2045, Ricoh AFICIO 2045E, Ricoh AFICIO 2045G, Ricoh AFICIO 2045P, Ricoh AFICIO 2045S, Ricoh AFICIO 3035, Ricoh AFICIO 3035G, Ricoh AFICIO 3035SP, Ricoh AFICIO 3035SPF, Ricoh AFICIO 3035SPI, Ricoh AFICIO 3045, Ricoh AFICIO 3045G, Ricoh AFICIO 3045SP, Ricoh AFICIO 3045SPF, Ricoh AFICIO 3045SPI, Ricoh AFICIO 340, Ricoh AFICIO 350, Ricoh AFICIO 350E, Ricoh AFICIO 355, Ricoh AFICIO 355E, Ricoh AFICIO 450, Ricoh AFICIO 450E, Ricoh AFICIO 455, Ricoh AFICIO 455E, Ricoh AFICIO AP4500, Ricoh AFICIO AP4510, Ricoh AFICIO MP3500, Ricoh AFICIO MP3500P, Ricoh AFICIO MP3500SP, Ricoh AFICIO MP3500SPF, Ricoh AFICIO MP3500SPI, Ricoh AFICIO MP4000, Ricoh AFICIO MP4000B, Ricoh AFICIO MP4000SP, Ricoh AFICIO MP4000SPF, Ricoh AFICIO MP4001G, Ricoh AFICIO MP4001SP, Ricoh AFICIO MP4500P, Ricoh AFICIO MP4500SP, Ricoh AFICIO MP4500SPF, Ricoh AFICIO MP4500SPI, Ricoh AFICIO MP5000, Ricoh AFICIO MP5000B, Ricoh AFICIO MP5000SP, Ricoh AFICIO MP5000SPF, Ricoh AFICIO MP5001G, Ricoh AFICIO MP5001SP, Ricoh AFICIO SP8100DN, Savin 2035DP, Savin 2035DPE, Savin 2045DP, Savin 2045DPE, Savin 2235, Savin 2245, Savin 2535, Savin 2535P, Savin 2545, Savin 2545P, Savin 4035, Savin 4035E, Savin 4045, Savin 4045E, Savin 4045G, Savin 4135EG, Savin 4135G, Savin 4145EG, Savin 4145G, Savin 8035, Savin 8035E, Savin 8045, Savin 8045E, Savin 8045EP, Savin 8045ESP, Savin 8045ESPF, Savin 8045ESPI, Savin 9040B, Savin 9040SP, Savin 9040SPF, Savin 9050, Savin 9050B, Savin 9050SP, Savin 9050SPF, Savin 9240G, Savin 9240SP, Savin 9250G, Savin 9250SP, Savin 9450DPE, Savin 9935D, Savin 9935DP, Savin 9935DPE, Savin 9945DP, Savin 9945DPE, Savin MLP145, Savin MLP45, Savin SLP45
Esperando sea de su utilidad este mensaje..... SUERTE y EXITO.
11/2/2011 06:11PM
Si lo que nesecitas el el codigo de la unidad de transferencia de la MP C 4500
color aca te lo dejo
Ricoh B2236032 Transfer Belt Unit.
Cuando pidas codigos de repuesto en el encabezado pone el modelo bien MP C 4500
Porque si pones MP solo se presta a confucion.
Espero que te sea de utilidad
jrf_62 455
04/11/2011 05:23PM
Buenas uds me podrían dar el numero de parte del conjunto de rodillos que van en la bandeja ADF en donde se colocan las copias para sacarlas, es un juego de rodillos color negro pequeños con una banda , agradezco su colaboraciòn
05/11/2011 12:42PM
manual de partes http://www.megaupload.com/?d=9LDFNXML (4.44 MB)
06/11/2011 02:23AM
hola Ing te paso los numeros ya tengo 9 años trabajando con las ricoh y lo que gustes aqui estamos
B223 6130 banda de transferencia de imagen mpc 2000 2500 3000 3500 4000 4500
09/11/2011 06:41PM
Buenas, tengo una maquina aficio 1035 (conectividad paralelo), hace tiempo he tenido una duda y pues ningun tecnico me ha sabido responder o decir a que se debe, lo que sucede es que la maquina ciertos archivos no los imprime, es decir algunos de word si otros no, algunos de excel si otros no, que puede ser? agradezco su ayuda.
02/9/2013 01:46PM
Hola estimados colegas necesito saber el código de parte de la placa de voltaje de mp 4500 y si saber si alguien reparo alguna ves esta placa... muchas gracias
02/9/2013 03:26PM
Toda esa información y esas miles de referencias que te dieron arriba te siven si tu maquina es blanco y negro, pero como la tuya es a color, los códigos que te brindaron
JRF_62 y DAVID ALEJANDRO son los correctos
