Código de error Minolta EP 3050
27/9/2004 04:42AM
Tengo una Minolta EP 3050 y necesito saber que significa CODE: COO72.
También me gustaría disponer de un listado y significado de los mensajes o códigos de error de este equipo.
Gracias anticipadas por su ayuda.
28/9/2004 04:52AM
C0000: Main Drive Motor M1’s Failure to Turn
C0001: Main Drive Motor M1 Turning at Abnormal Timing
C0040: Suction Fan Motor M4’s Failure to Turn
C0046: Fusing Section Cooling Fan Motor M15’s
C0047: Fusing Section Cooling Fan Motor M15 Turning at Abnormal Timing
C004A: Original Glass Cooling Fan Motor M5’s Failure to Turn
C004b: Original Glass Cooling Fan Motor M5 Turning at Abnormal Timing
C004C: Ventilation Fan Motor M3’s Failure to Turn
C004d: Ventilation Fan Motor M3 Turning at Abnormal Timing
C0070: Main Hopper Toner Replenishing Motor M8’s Failure to Turn
C0071: Main Hopper Toner Replenishing Motor M8 Turning
C0072: Sub Hopper Toner Replenishing Motor M9’sFailure to Turn
C0200 Corona Malfunctions
C03##: Master Board/Harness Malfunctions
C0400: Exposure Lamp LA1’s Failure to Turn ON
C0410: Exposure Lamp LA1 Turning ON at Abnormal Timing
C0500: Warming-up Failure
C0510: Abnormally Low Fusing Temperature
C0520: Abnormally High Fusing Temperature
C0600: Scanner Motor M2 Malfunction
C06FX: Signal Failure
C0610: Lens Motor M6 Malfunction
C0620: Mirror Motor M7 malfunction
C0910: 2nd Drawer Upward Motion Failure
C0914: 2nd Drawer Paper Lift-Up Motor M14’s Failure to Turn
C0920: 1st Drawer Upward Motion Failure
C0924: 1st Drawer Paper Lift-Up Motor M13’s Failure to Turn
C0900: 3rd Drawer Upward Motion Failure
C0904: 3rd Drawer Paper Lift-Up Motor M24’s Failure to Turn
C0950: 4th Drawer Upward Motion Failure
C0954: 4th Drawer Paper Lift-Up Motor M25’s Failure to Turn
C0911: 2nd Drawer Upward Motion Failure (Inch Areas)
C0912: 2nd Drawer Downward Motion Failure
C0913: 2nd Drawer Upward Motion Failure
C0916: 2nd Drawer Ejection Failure
C0921: 1st Drawer Upward Motion Failure (Inch Areas)
C0922: 1st Drawer Downward Motion Failure
C0923: 1st Drawer Upward Motion Failure
C0926: 1st Drawer Ejection Failure
C0901: 3rd Drawer Upward Motion Failure (Inch Areas)
C0902: 3rd Drawer Downward Motion Failure
C0903: 3rd Drawer Upward Motion Failure
C0906: 3rd Drawer Ejection Failure
C0951: 4th Drawer Upward Motion Failure (Inch Areas)
C0952: 4th Drawer Downward Motion Failure
C0953: 4th Drawer Upward Motion Failure
C0956: 4th Drawer Ejection Failure
C0990: Main Tray Upward Motion Failure
C0991: Main Tray Downward Motion Failure
C0992: Main Tray Downward Motion Failure
C0993: Main Tray Upward Motion Failure
C0994: Elevator Motor M26’s Failure to Turn
C0998: Shifter Transfer Failure
C0999: Shifter Return Failure
C099A: Shifter Return Failure
C099b: Shifter Transfer Failure
C099C: Shift Motor M27’s Failure to TurN
C099E: Shift Gate Position Detecting Failure
C099F: Shift Gate Position Detecting Failure
C0996: 3rd Drawer Lock Release Failure
C0F79: Paper Empty Sensor Failure
C0d00: Duplex Unit Front/Rear Edge Guide Plate Home Position Detection
C0d20: Duplex Unit Gate Unit Home Position Detection Failure
C0d50: Duplex Unit Drive Motor M31’s Failure to Turn
C0d51: Duplex Unit Drive Motor M31 Turning at Abnormal Timing
C0E00: Main Erase Lamp LA2’s Failure to Turn ON T-97 . . . . . . . . . . .
C0E01: Main Erase Lamp LA2 Turning ON at Abnormal Timing
C0E20: Image Erase Lamp LA3’s Failure to Turn ON T-98 . . . . . . . . .
C0F02: Original Size Detecting Board UN2 Malfunction T-99 . . . . . . .
C0F10: AE Sensor Board PWB-H Malfunction T-101 . . . . . . . . . . . . . .
C0F20: AIDC Sensor Board PWB-G Variation Correction Failure
C0F22: AIDC Sensor Board PWB-G Grid Voltage (Vg)
C0F23: AIDC Sensor Board PWB-G Exposure Correction Failure
C0F30: ATDC Sensor UN3 Failure
C0F31: ATDC Sensor UN3 Failure
NAC125 211
