Notice: Undefined index: logueado in /disk1/yoreparo.com/config/config.produccion.php on line 250 Canon IR3200 - Reparación de Fotocopiadoras - YoReparo
Canon IR3200
05/9/2007 01:50PM
amigos, acaba de aterrizar una IR3200 en mi taller y necesitaría si alguno tiene información técnica o por lo menos de codigos de error en esa copiadora. Tengo experiencia en IRC1120/50 y se entra al mantenimiento de igual manera
osvman 1
05/9/2007 05:31PM
hola,aca te dejo los codes de error...
Canon iR2200 / iR2800 / iR 3200 /iR3300
E000 0000 The reading of the main thermistor does not reach 30oC 1 sec after the main power switch is turned on. Or, it does not reach 70oC 2 sec thereafter
E001 0000 The main thermistor detects 250oC or higher
0001 The main thermistor or the sub thermistor detects overheating (hardware circuit detection)
0002 The sub thermistor detects about 295oC or higher
E002 0000 The temperature of the fixing film is as follows:
• has exceeded 100oC, but does not reach 115oC within 1 sec thereafter.
• has exceeded 140oC, but does not reach 150oC within 1 sec thereafter.
• has exceeded 160oC, but does not reach 165oC within 1 sec thereafter
E003 0000 The main thermistor reading is lower than 140oC when paper is moved
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100oC or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven
E010 0000 After the main motor drive signal is generated, the clock signal does to arrive within 1.3 sec
E014 000 After the fixing motor drive signal is generated, the clock signal does not arrive within 1.3 sec
E019 0000 The waste toner case is full of waste toner
E032 0001 The DA unit connection is disconnected (after connection).
E051 0000 At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position
E064 0000 The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage)
E100 0001 The BD signal is not detected 10 times or more within 10 msec in 5 msec after the generation of the laser drive signal
0002 While the laser is ON, the BD signal cycle is outside a specific range 20 times or more continuously
0003 While the laser is ON, the horizontal sync signal cycle is outside a specific range 20 times or more
E110 0000 The motor ready signal does not arrive within 15 sec after the laser scanner motor drive signal is generated
E202 0001 The scanner home position sensor does not go OFF when the scanner is moved forward by 40 mm
0002 The scanner home position sensor does not go ON when the scanner is moved reverse 450 mm
E204 0001 While an original is being read, the image leading edge signal does not arrive from the ADF
E220 0001 A fault is detected on the inverter PCB for the scanning lamp
E225 0000 A specific level cannot be attained for the signal during CCD gain correction at power-on
0002 The edge gain correction level is different from the correction level for the preceding sheet by a specific level or more
E240 0000 A fault occurs in communication between the CPU of the main controller PCB and the CPU of the DC controller PCB
E243 0000 A fault occurs in the communication between the CPU of the control panel PCB and the CPU of the main controller PCB
E248 0001 A difference is discovered between the ID in EEPROM read when the main power switch is turned on and the ID in ROM upon comparison
0002 The data read does not match the data written to EEPROM
0003 A difference is discovered between the ID of EEPROM and the ID of ROM upon comparison while writing data
E261 0000 The intervals of zero-cross signals deviate from the tolerance range while the fixing heater is supplied with power
E302 0001 During shading, the shading processing does not end on the reader controller PCB after 1 sec
0002 During stream reading, the edge white addition processing does not end on the rear controller PCB after 10 sec
E315 - Any of the following is true in the image processing by the main controller:
• The image data has a fault
• The encoding/decoding operation for image data has a fault
• The image processing element of the main controller PCB has a fault
E601 0000 When an image is transferred between the main controller PCB and the HDD, the main controller PCB detects a fault in control information
0001 When an image is transferred between the main controller PCB and the DC controller PCB, the DC controller PCB detects a fault in the control information
E602 0001 A mounting fault of the HDD is detected when the HDD is started up from the BOOT ROM
0002 A data read fault of the HDD is detected when the HDD is started up from the BOOT ROM
E604 0000 A fault is detected in the image memory
E605 0001 A fault is detected in the battery for the image memory
E606 0001 A mounting fault of the HDD is detected when the HDD is started up from the BOOT ROM
E674 0000 A faulty occurs in the communication between the fax PCB and the main controller PCB
E677 0001 A fault occurs it the combination between any of the printer boards (accessories) and the main controller PCB
E710 0001 When the main power is turned on, the communication IC (IPC) on the reader controller PCB cannot be initialized
0002 When the main power is turned on, the communication IC (IPC) on the DC controller PCB cannot be initialized
0003 When the main power is trend on, the communication IC (IPC) on the main controller PCB cannot be initialized
E711 0001 Data is written to the error register of the communication IC (IPC) on the reader controller PCB four times or more within 1.5 sec
0002 Data is written to the error register of the communication IC (IPC) on the DC controller PCB four times or more within 2 sec
0003 Data is written to the error register of the communication IC (IPC) on the main controller PCB four times or more within 2 sec
E712 0001 The communication is not resumed 3 sec or more after data has been written to the error register of the communication IC (IPC) on the ADF controller PCB
0002 The transmission bit is not enabled 10 sec or more in the sync register of the communication IC (IPC) on e reader controller PCB
E713 0000 The communication with the finisher is not resumed 3 sec or more after it is disrupted
E716 0000 The ID signal is not detected within a specific period of time after the presence of a pedestal is detected
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E717 0001 The communication with the DA unit is not resumed 3 sec or more after it is disrupted
E719 0001 The communication between the Card Reader-C1 or the coin vendor and the main controller PCB is disrupted
E732 0001 A fault is detected by the main controller PCB in the communication between reader controller PCB and the main controller PCB
E733 0001 A fault is detected by the main controller PCB in the communication between the DC controller PCB and the main controller PCB
E737 0000 During self diagnosis at power-on, the DRAM check finds a fault in the main controller PCB
E740 0001 At power-on, the LAN card has a fault
0002 The MAC address has a fault
0003 The LAN card cannot be read
E741 0000 The PCI bus has a fault
E743 0000 The reader controller PCB detects a fault in the communication between the main controller PCB and the reader controller PCB
E744 0000 The BootROM on the main controller PCB and the system software are for different models or are of different types
E803 0000 The 24V output from the composite main power supply PCB is absent for 1 sec or more
E805 The clock signal is absent for 5 sec or more after the fan drive signal has been generated. The detail codes of the fans in question are as follows:
0001 developing fan (FM1)
0002 fixing fan (FM2)
0003 curl reducing fan (FM4)
0004 curl reducing fan (FM5)
0005 electrical unit fan (FM3)
E901 0000 The motor ready signal does not arrive within 1.3 sec after the pedestal main motor drive signal is generated
ADF Error Codes
E420 0001 When the power switch of the host machine is turned on, the back-up data from the EEPROM cannot be read or the data that has been read has a fault
E421 0001 The back-up data cannot be written to the EEPROM, or the data that has been written has a fault
E422 0001 While the ADF is in standby, the communication with its host machine is disrupted for 5 sec or more; or, while the ADF is in operation, the communication with its host machine is disrupted for 0.5 sec or more
Saddle Finisher-G1 Error Codes
E501 0001 The communication between the finisher controller PCB and the puncher drive PCB is disrupted
E505 0001 When the main power is turned on, the checksum of the finisher controller PCB has a fault
0002 When the main power is turned on, the checksum of the puncher driverPCB has a fault
E510 0001 The feeding roller does not leave home position when the feed motor is driven for 2 sec
0002 The feeding roller does not return to home position when the feed motor is driven for 2 sec
E514 0001 The delivery belt does not leave home position when the stack delivery motor is driven for 3 sec
0002 The delivery belt does not return to home position when the stack delivery motor is driven for 3 sec
E530 0001 The aligning plate (rear) does not leave home position when the alignment motor (rear) is driven for 3 sec
0002 The aligning plate (rear) does not return to home position when the alignment motor (rear) is driven for 3 sec
E531 0001 The stapler does no leave home position when the stapler/folder motor is driven for 1.5 sec
0002 The stapler does not return to home position when the stapler/folder motor is driven for 1.5 sec
0003 The clock signal is disrupted for 1 sec or more while the stapler/folder motor is driven
E532 0001 The stapler unit does not leave home position when the stapler slide motor is driven for 4.5 sec
0002 The stapler unit does not return to home position when the stapler slide motor is driven for 4.5 sec
E537 0001 The aligning plate (front) does not leave home position when the alignment motor (front) is driven for 3 sec
0002 The aligning plate (front) does not return to home potion when the alignment motor (front) is driven for 3 sec
E540 0001 The paper surface sensor remains unchanged 10 sec after the tray ascent/ descent motor is driven
0002 The tray upper sensor goes ON while the tray is moving up.
0003 The clock for the clock sensor is disrupted for 10 sec or more while the tray ascent/descent motor is driven
E577 0001 The paddle does not leave home position when the paddle motor is driven for 2 sec or more
0002 The paddle does not return to home position when the paddle motor is driven for 2 sec or more
0003 The stack ascent/descent guide does not leave home position when the paddle motor is driven for 2 sec or more
0004 The stack ascent/descent guide does not return to home position when the paddle motor is driven for 2 sec or more
E590 0001 The puncher does not return to home position when the puncher motor is driven for 250 msec
0002 The clock from the puncher motor clock sensor is disrupted for 60 msec or more when the puncher motor is driven
E592 In the course of sensor output automatic adjustment, the light-receiving voltage is 2.5 V or less even when the light-emitting voltage is set to 4.4 V. In the course of output automatic adjustment, the light-receiving voltage is 2.5 V or more even when the light-emitting voltage is set to 0 V. In the course of sensor output automatic adjustment, the light-emitting voltage is set to 4.4 V or more
0001 to 0005 Horizontal registration sensor
0006 Puncher waste full sensor
E593 0001 The puncher not leave home position when the puncher shift motor is driven for 1 sec
0002 The puncher does not return to home position when the puncher shift motor is driven for 1 sec
E5F1 0001 The folding roller does not leave home position when the stapler/folder motor is driven for 1.5 sec
0002 The folding roller does to return to home position when the stapler/folder motor is driven for 3.5 sec or more
0003 The clock is disrupted for 1 sec or more while the stapler/folder motor is driven
Finisher-J1 Error Codes
E500 0000 The communication between the copier and the finisher is disrupted and is not corrected for 5 sec or less
E514 0000 At the start of the motor CW operation, the stack handling motor (M2) may be driven for a specific number of rotations; however, the stack delivery lever home position sensor (SCool does not go ON
E530 0000 The alignment motor (M4) is driven for a specific number of rotations, but the aligning plate home position sensor (S7) does not go ON. The alignment motor (M4) is driven for a specific number of rotations, but the aligning plate home position sensor (S7) does not go OFF
E531 0000 The stapling home position sensor (S16) does not go off 0.5 sec after the stapler motor is rotated CW. The stapling home position sensor (S16) dos not go ON with 0.5 sec after the stapler motor is rotated CW and, thereafter, the sensor does not go ON within 0.5 sec after the motor is rotated in reverse
E537 0000 The aligning plate home position sensor (S6) does not go ON when the front alignment motor (M3) is driven for a specific number of rotations. The aligning plate home position sensor (S6) does not go OFF when the front alignment motor (M3) is driven for a specific number of rotations
E577 0000 The return roller does not reach home position when the delivery motor (Ml) has been driven as much as will move it to the return roller home position sensor (S3)
E580 0000 The delivery tray upper limit sensor (S13) goes ON while the delivery tray ascent/descent motor (M5) is in operation.
The clock signal of the delivery tray ascent/descent motor clock sensor (S9) is not detected 15 times or more within 0.8 sec while the delivery tray ascent/ descent motor (M5) is in operation.
The delivery tray paper height sensor (S10) does not go ON 4 sec after the delivery tray ascent/descent motor (M5) starts to move up.
The delivery tray paper height sensor (S10) does not go OFF 4 sec after the delivery tray ascent/descent motor (M5) starts to move down
E585 0000 At the start of the motor CCW operation, the stack handling motor (M2) may be driven for a specific number of rotations; however, the stack delivery lever home position sensor (SCool does not go ON
suerte
