[Solucionado] Canon codigos de errores
03/5/2007 01:12PM
Colegas alguno de ustedes podría ser tan amable de facilitarme algún documento sobre los códigos de errores de las fotocopiadoras canon.
Mil gracias
MALL
03/5/2007 01:20PM
hola,aca te dejo estos ,pero debes indicar de que modelo requieres..
CODIGOS DE ERRORES
NP-1215
E000 - Thermistor , heater, AC Driver PCB, DC Controller PCB, operation of thermoswitch.
E001 - Defective thermistor, AC Driver PCB, DC Controller PCB
E030 - Counter, DC Controller PCB
E202 - Scanner Home Position sensor, Scanner motor, motor Controller PCB, DC Controller PCB
E210 - Lens home position sensor, lens motor, DC controller PCB
E221 - Lamp regulator, DC controller PCB
E400 - DF controller PCB, DF power supply, DC controller PCB
E500 - Sorter controller PCB, DC controller PCB
NP-6012
E000 - Fuser problem. Low temperature. Lamp, thermal switch, AC driver
E001 - Fuser problem. High temperature. Triac, AC driver, pinched wire
E004 - Fuser problem
E0053 - Sorter
E030 - Counter
E202 - Scan
E210 - Lens
E221 - Exposure lamp regulator board, thermal fuse, exposure lamp
E400 - Automatic document feeder
E500 - Sorter
E710 - DC controller
C - No problem. Means that the machine is correcting the fuser film tracking.
CC - Drum must be changed. Could be the drum serial number is identified by the logic as being non-compatible to that particular copier.
E000 - Low fuser temperature
E001 - High fuser temperature
E002 - High fuser temperature
E003 - Erratic fuser temperature
E007 - Fuser film off track and will not repair itself
E010 - Main drive problem
E030 - Counter problem
E064 - Scan problem, or power supply
E202 - Scan problem
E210 - Lens drive problem or lens sensor
E220 - Exposure lamp stays on or off
E240 - DC controller (main board) or composite power supply
E261 - Zero cross problem. Power frequency or composite power supply
E400 - Communication problem between boards
E803 - 24 volt problem
EO - Fuser problem
H - Fuser overheat
E000 - Fuser thermistor, heater, thermal fuse
E001 - Fuser thermistor, or triac
E002 - Fuser thermistor, thermal fuse or triac
E003 - Fuser thermistor, heater, thermal fuse or triac
E004 - Triac or fuser won't shut off
E007 - Fuser film is off center or not driving properly
E010 - Main motor drive problem
E030 - Counter
E064 - Composite power supply or main board
E202 - Scan problem
E240 - Main board or composite power supply
E261 - Composite power supply or fluctuating power
E400 - ADF communication problem to machine
E402 - ADF belt motor drive
E404 - ADF exit motor
E411 - ADF document detect, or registration sensor or edge sensor
E500 - Sorter communication problem
E510 - Sorter drive problem
E530 - Stapler guide bar motor
E531 - Stapler swing motor
E540 - Bin shift motor
E541 - Bin motor drive problem
E710 - Main board
E711 - Main board
E712 - Main board or communication problem with ADF
E717 - Main board, asst. board
U0 - Initializing. Sets all user modes to factory default settings
U1 - Auto clear timer. Range 1-9. Each digit=1 minute
U2 - Automatic power shut off timer
U3 - Fine adjustment of zoom
U4 - Auto cassette switching
U5 - Sort or non-sort default
U6 - Cleans document feeder pickup assembly
U7 - CLEAR "replace drum"
U9 - Auto exposure or manual exposure as default
E000 - Fuser did not heat up
E001 - Fuser temperature too high
E002 - Fuser temperature not rising at correct pace
E003 - Fuser temperature drops
E004 - SSR shorted
E210 - Lens home problem
E212 - Lens home problem
E220 - Exposure lamp problem
E224 - Blank shutter home problem
E240 - DC controller or composite power supply problem
E400 - Data communication problem
E401 - Pickup motor problem
E402 - Belt motor problem
E403 - Feeder motor
E404 - Delivery motor
E411 - Document detect sensor
E500 - Communication problem with copier
E510 - Feeder motor
E530 - Home sensor
E531 - Staple swing sensor problem
E540 - Bin shift motor rotation problem
E541 - Bin motor
E711 - Document feeder IC failure
E716 - Cassette feed IC failure
E800 - Auto power-off circuit problem
E901 - Cassette feed motor
E902 - Paper guide home sensor problem
E000 - The temperature of the upper fixing roller does not reach 100 C within 5 min after powering-on.
E000 - Fuser Problem
E001 - The temperature of the upper fixing assembly remains 230 C or more for 5 seconds or more.
E002 - Fuser temperature not rising at the correct pace
E002 - The temperature of the upper fixing roller does not reach 180 C within 5 min after it has exceeded 100 C.
E003 - The temperature of the upper fixing roller is below 100 C or less for 5 seconds after it has reached 180 C.
E003 - Fuser temperature not rising at the correct pace
E005 - Fuser cleaner belt problem
E005 - The length of the cleaning belt taken up (fixing assembly) is more than a specified length.
E010 - Drive problem (main motor)
E010 - In response to the main motor drive signal, two or more clock pulses are not generated within 1 second.
E013 - Toner waste problem
E013 - When rotation of waste toner feeder screw becomes disabled and the sensor switch (SW20) is pressed.
E020 - During copying operation, the black toner supply signal is "0" (no toner) for 3 min or more. At time of installation, the black toner supply signal does not go "1" within 6 min during black toner supply sequence.
E020 - No toner being fed for 3 min after toner was called for
E030 - A counter open circuit is identified when counter drive is OFF.
E030 - Counter
E050 - The tray home position signal (THP) is not generated within 4 sec while the paper guide motor dive signal is generated.
E050 - Duplex problem
E203 - Scan home problem
E203 - The scanner home position signal (SCHP) is generated 2 pulses or more within 0.5 sec when the scanner motor is turned ON.
E210 - The lens x home position signal (LXHP) is not generated within 9 sec after the power switch or the door switch is turned ON. The lens x home position signal (LXHP) is generated for 2 sec or more.
E212 - The lens y home position signal (LYHP) is not generated within 9 sec after the power switch or the door switch is turned ON. The lens y home position signal (LYHP) is generated for 2 sec or more.
E400 - Communication problem with copier
E401 - Pickup motor or motor sensor
E402 - Belt motor or motor sensor
E403 - Feed motor or motor sensor
E404 - exit motor or motor sensor
E405 - Pick up motor sensor
E406 - Side guard motor or motor sensor
E407 - Tray motor or position sensor
E411 - Sensor for document detection
E431 - Sub registration sensor
E441 - Motor
E442 - Cooling fan problem
E446 - CFF mirror motor or sensor
E447 - CFF out of position or bad position sensor
E510 - Feed motor drive
E513 - Tandem feed motor drive
E530 - Staple guide motor or sensor
E540 - Bin shifting motor
E710 - Q124 on the DC controller PCB cannot be initialized at power-on.
E710 - DC controller (main board)
E711 - DC controller
E711 - Q124 on the DC controller is faulty after power-on.
E712 - The communication IC on the RDF-A1 controller is faulty.
E712 - 24 volt power supply or RDF-A1 main board
E715 - The communication IC on the C.F.F. controller PCB is faulty.
E715 - Computer form feeder board problem
E800 - An open circuit is identified in the auto power-off mechanism. The auto power-off signal is generated twice or more in 2 sec.
E800 - Auto power shut off problem. Main board
E2 - Scanner
EO - Heat lamp
E000 - Fuser thermistor, heater thermal fuse
E003 - Fuser thermistor, heater, thermal fuse or triac.
E007 - Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407
E030 - Counter
E041 - Paper deck motor, clutch or sensor
E064 - Composite power supply or main motor board
E202 - Scan problem. Motor sensor.
E240 - Main board or composite power supply.
E260 - Main board, power supply cooling fan or composite power supply.
E261 - Composite power supply or fluctuating power.
E400 - ADF communication to machine.
E401 - ADF pickup motor or sensor.
E403 - ADF feed motor or slip sensor.
E500 - Sorter communication problem.
E510 - Sorter drive problem.
E530 - Stapler guide bar motor.
E531 - Stapler swing motor.
E540 - Bin shift motor.
E541 - Bin motor drive problem.
E710 - Main board (DC controller.)
E711 - Main board (DC controller.)
E712 - Main board or communication problem with ADF, or ADF main board.
E717 - Main board, assist board. "Replace drum": Drum waste toner is full, or drum has run 40,000 copies. Reset with user
E802 - Composite power supply or DC controller.
E901 - Cassette feed unit board or cassette feed motor.
E902 - Horizontal registration problem. I think this refers to the duplex section.
J1 - Feed jam
J10 - Duplex exit jam
J11 - Vertical jam
J12 - Vertical jam
J13 - Vertical jam
J14 - Vertical jam
J15 - Deck jam
J2 - Feed jam
J3 - Separation area jam
J4 - Separation area jam
J5 - Exit jam
J6 - Exit jam
J7 - Sorter jam
J8 - Door open jam
J9 - Cassette jam
JA - Cassette jam
Jb - Cassette jam
JC - Cassette jam
Jd - Duplex feed jam
JE - Duplex exit jam
JF - Duplex registration jam
GP-200-215
E000 - Fixing temperature fails to rise
E001 - Fixing temperature rises abnormally
E002 - Fixing temperature fails to reach a specific value
E003 - Fixing temperature drops abnormally
E007 - Fixing film has become displaced
E010 - The main motor fails to lock
E030 - Total counter failure
E031 - Option counter failure
E032 - The copy data controller counter is faulty
E051 - The horizontal registration home position detection mechanism fails
E064 - The high voltage (primary charging, transfer charging, developing) output is faulty
E100 - BD Error
E110 - The laser scanner motor fails to lock
E190 - RAM error
E191 - Communication error between the DC controller & composite power supply
E202 - Scanner home position cannot be detected
E220 - Scanning lamp fault
E240 - Communication error in the DC controller
E243 - Communication error between control panel & image processor PCB
E261 - Error in the zero cross signal
E301 - Intensity of scanning lamp is not correctly adjusted
E400 - Communication error between copier and RDF-G1
E401 - Pick up error in RDF-G1
E402 - Belt drive fault in RDF-G1
E403 - Feeder fault in RDF-G1
E411 - Original tray paper sensor/ registration sensor in RDF-G1
E422 - Communication error between copier and ADF-F1
E710 - Error in IPC communication
E711 - Error in IPC communication
E712 - Error in communication with the feeder
E713 - An IC error has occured (sorter)
E716 - Communication error with the pedestal
E717 - Communication error with the copy data controller
E803 - Error in the output voltage of the composite power supply PCB
E901 - Pedestal motor or controller PCB
saludos y suerte
03/5/2007 06:48PM
Estimado Calos Marenco muchas gracias por la información que me haz dado, el problema es que tengo que comenzar a reparar este tipo de equipos y de esta marca y me hacía falta este tipo de información en sentido general.
¿Por casualidad no tendrás información sobre el principio de funcionamiento de las fotocopiadoras, y las principales fallas que dan y sus posibles soluciones, sobre todo para las de la marca Canon?
Gracias mil
MALL
03/5/2007 07:21PM
hola,a la orden,aca te dejo un post en que encontraras unos archivos con teoria...
http://www.yoreparo.com/foros/reparacion_de_fotocopiadoras/80647.html
saludos y suerte
04/5/2007 12:12PM
Carlos colega nuevamente te doy las gracias por la gran ayuda que me haz dado, disculpa si no puedo valorar tu respuesta como solución pero es que no puedo, me dice que solo puede haber una sola solución.
Te reitero mis agradecimientos
MALL
