[Solucionado] buen dia tengo ricoh 2045 aficio codigo c426
20/4/2017 09:22AM
hola queria saber si alguien me puede ayudar con esta falla la maquina escanea y tarda en pasar la copia y despues marca ese codigo c426 .desde ya les agredesco
20/4/2017 12:38PM
el codigo de error sc 426 no es correcto....
revisa y comentanos bien el codigo para poder ayudarte.
bebucho 1786
20/4/2017 05:43PM
si el error es 226, tienes problemas con el laser...hay que desmontar, limpiar y ajustar...de preferencia por un experto..y si no queda...pues sustituirlo
25/4/2017 06:53PM
401 C Transfer roller leak detected
A transfer roller current leak signal is
detected.
• High voltage supply board defective
• Poor cable connection or defective
cable
• Transfer connector defective
402 C Transfer roller open error
The transfer roller current feedback
signal is not detected.
• Transfer connector cable defective
• Poor PCU connection
403 C Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once.
• Main motor/drive malfunction
• Transfer belt contact clutch defective
• Harness disconnected
405 C Transfer belt error
The transfer belt does not move away
from the drum during ID sensor pattern
checking.
• Transfer belt position sensor
defective
• Poor transfer belt position sensor
connection
440 C Main motor lock
A main motor lock signal is not detected
within 2 seconds after the main motor
turns on.
• Too much load on the drive
mechanism
• Main motor defective
450 Feed Development Motor Error
C
The PLL lock signal remains LOW for 2
s while the feed development motor is
operating.
• Motor lock caused by overload.
• Motor driver defective.
490 C Exhaust fan motor lock
An exhaust fan motor lock signal
